Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open |
| Print at Oct 4, 2026, 3:09:54 AM | |
| Posted by HammerCam at Jan 10, 2021, 7:34:26 PM |
Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open Just purchased from the Apple Mac App store and it tries to open, but doesn't actually open - just crashes. Trying to see what I need to do to install but everything references an older version of Sweet Home 3D and not v6.4.7. Java is installed and everything I download directly from your website also crashes and doesn't open. Running macOS Big Sur v11.1 on a MacBook Pro (15-inch, 2019) Looking for direction, was referred to this product from multiple people, excited to give it a whirl. |
| Posted by Puybaret at Jan 10, 2021, 9:24:26 PM |
Re: Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open Could you try to run it from a Terminal window? Open Terminal application, drag and drop Sweet Home 3D icon on Terminal window, add /Contents/MacOS/SweetHome3D after Sweet\ Home\ 3D.app to obtain something like: /Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by tdavisson at Jan 28, 2021, 6:38:10 PM |
Re: Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open Running to this exact same issue. When I followed your instructions above to run it through terminal I was successful in getting the program to launch. Any thoughts? |
| Posted by Puybaret at Jan 29, 2021, 2:07:34 PM |
Re: Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open Could you check if you have this issue with the free version 6.4.2 and in the beta version 6.5? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Joan20 at Feb 11, 2021, 4:07:42 AM |
Re: Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open Following this. I am having this issue with the beta 6.5 |
| Posted by Puybaret at Feb 11, 2021, 7:48:50 AM |
Re: Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open Joan20, your last message made me think you was a Ubuntu user. Did you change your computer? Does it run from a Terminal window? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by silaspeter at Feb 18, 2021, 5:51:09 PM |
Re:
Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open Has this problem been solved. I wil not upgrade to Big Sur if it has not |
Current timezone is GMT Oct 4, 2026, 3:09:54 AM |
