Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Modify level - what elevation, floor thickness and height affect |
| Print at Oct 9, 2026, 7:34:57 PM | |
| Posted by vmq at Jan 10, 2021, 8:35:09 PM |
Modify level - what elevation, floor thickness and height affect After adding levels to my current project and loosing the vaulted ceiling that I had added for the living room area I started searching the User's Guide, the in program help and Google for a concise summary how elevation, floor thickness and height really work. After playing with a test drawing I found the following additional information:
Did I get that right, or am I missing other effects? |
| Posted by Puybaret at Jan 13, 2021, 12:27:56 PM |
Re: Modify level - what elevation, floor thickness and height affect Your summary is correct, except for the following comment: This thickness [...] is seen from lower levels with the color or texture that is used for the floor of the corresponding room when looking up from lower floors. The color or texture seen from lower levels is rather the color or texture set for the ceiling of the rooms at the lower level, as you explain it in the 3rd point. Actually, you comment is true only if there's no room at the lower level. See also the Managing the ceiling at first floor section in this tip. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 9, 2026, 7:34:57 PM |
