Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: 'Levels' Tab Arrangement Changed? |
| Print at Oct 7, 2026, 3:13:41 PM | |
| Posted by rndlmn4 at Jan 25, 2021, 3:42:24 AM |
'Levels' Tab Arrangement Changed? The tabs for Levels, which sit below the tool bar and above the horizontal scale, were in a single row for the longest time. Now all of a sudden they appear in two rows. The strange thing is, when you select a Level, the row it is in becomes to the bottom row. If you select another Level from that row, the tabs don't change. But, if you select a Level from the top row, all of that row becomes the bottom row, and the other row moves up. It's causing me to work with a moving target. I spend too much time looking for the correct tab before clicking. How can I put all of the tabs back into one row? |
| Posted by Cika at Feb 26, 2021, 6:15:00 PM |
Re: 'Levels' Tab Arrangement Changed? I don't think you can, it's the same problem I have. When you have as many levels as me about 60, the automatic repositioning is crazy, it would be better if they stood still in their position. I hope someone can find a solution, because the program is fantastic |
Current timezone is GMT Oct 7, 2026, 3:13:41 PM |
