Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 6.5 |
| Print at Aug 9, 2026, 2:49:05 PM |
| Posted by Puybaret at Feb 18, 2021, 9:26:20 AM |
Re: Sweet Home 3D 6.5 Thanks for your feedback. @bdfd and reddy.shyam: What beta version do you use? By "jumping", do you mean that the pointer moves by itself to another place? @snmavronis Maybe one day I'll remove Java 3D bridge and use JOGL directly, but there are very little chances that Sweet Home 3D will be reprogrammed (again) in an other language. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Feb 18, 2021, 10:01:50 AM |
Re: Sweet Home 3D 6.5 Actually, 6.5 beta4 @bdfd and reddy.shyam: What beta version do you use? By "jumping", do you mean that the pointer moves by itself to another place? YES ! especially when you want to move an object or a group. . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by reddy.shyam at Feb 18, 2021, 10:04:33 AM |
Re: Sweet Home 3D 6.5 Thanks for your feedback. @bdfd and reddy.shyam: What beta version do you use? By "jumping", do you mean that the pointer moves by itself to another place? @snmavronis Maybe one day I'll remove Java 3D bridge and use JOGL directly, but there are very little chances that Sweet Home 3D will be reprogrammed (again) in an other language. Hi @Puybaret, to me I have click couple of mm away from the object to select it. I am on beta4. |
| Posted by Puybaret at Feb 18, 2021, 10:20:36 AM |
Re: Sweet Home 3D 6.5 Could you check if you have the same problem with the version 6.5 Beta 3? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Feb 18, 2021, 11:09:55 AM |
Re: Sweet Home 3D 6.5 Could you check if you have the same problem with the version 6.5 Beta 3? Yes for me. . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by reddy.shyam at Feb 18, 2021, 2:22:07 PM |
Re: Sweet Home 3D 6.5 Could you check if you have the same problem with the version 6.5 Beta 3? Mee too. |
| Posted by Puybaret at Feb 18, 2021, 3:31:23 PM |
Re: Sweet Home 3D 6.5 Could you send me a video showing the bug (ideally using a demo available from File > New from demo menu item)? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Feb 22, 2021, 10:21:40 AM |
Re: Sweet Home 3D 6.5 @bdfd and reddy.shyam: please give more details about how to reproduce the issue you reported. I didn't experience it on my side. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by reddy.shyam at Feb 22, 2021, 4:12:08 PM |
Re: Sweet Home 3D 6.5 @bdfd and reddy.shyam: please give more details about how to reproduce the issue you reported. I didn't experience it on my side. Hi Emmanuel, Apologies, totally skipped my mind. Just emailed you. Thanks for the reminder. :) |
| Posted by YGYL at Feb 22, 2021, 5:38:24 PM |
Re: Sweet Home 3D 6.5 I used beta 4 twice and found no problem WIN10 |
Current timezone is GMT Aug 9, 2026, 2:49:05 PM |
