Print at Sep 28, 2026, 11:43:28 PM
Posted by meengrn at Feb 7, 2021, 9:40:03 PM
Shop Equipment and Tools
I've searched this forum and all the libraries I can find for shop equipment with no luck. Table saws, drill presses, tool cabinets, peg board, bench grinders and similar. Any guidance appreciated.
Posted by hansmex at Feb 12, 2021, 9:04:53 AM
Re: Shop Equipment and Tools
On the 3D models page, the Trimble Sketchup Warehouse is listed.
Obviously you didn't look there....
table saw
drill press
tool cabinet
peg board
bench grinder
Posted by jarroyo at Apr 30, 2022, 6:15:29 PM
Is there a way to convert the SKP file formats to a compatible format (obj, dae, kmz, or 3ds) to use with Sweet Home 3d?
Posted by rustypheonix at Sep 1, 2022, 6:04:13 PM
I have found that I do not need to convert when I download from the Trimble warehouse. There is an option at the bottom of the pull down menu in that site when you download the item to down load in Collada format. Sweethome can import those files just fine. Now if you find a SKP file somewhere else, there are online converters that I found, but not tried, that can convert to OBJ format.
Posted by Puybaret at Sep 1, 2022, 10:31:59 PM
Yes, as explained in this page wink
