Print at Oct 8, 2026, 4:44:51 AM
Posted by Robbyvenetian at Feb 15, 2021, 1:03:13 AM
Ground level change?
Hello people, After I created a two story model, I discovered I needed to add few inches of bricks to elevate the first floor from the ground. Is there any way to lower down the ground, or I need to elevate everything I already created? Thank you.
Posted by Denis1874 at Feb 15, 2021, 9:54:07 PM
Re: Ground level change?
Hello, I don't think it is possible to lower down the ground, but you can adjust the elevation of levels through the levels panel (double click on one level at the top of your window) to get it.
MacMini 3GHz Intel Core i5 6 cores 64Go macOS Big Sur 12.2.1
