Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...) |
| Print at Sep 26, 2026, 10:24:43 AM | |
| Posted by HABITALIA at Feb 25, 2021, 7:01:10 AM |
THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...) HELLO: THE OTHER DAY I CLOSED THE APPLICATION AND WHEN I OPENED IT AGAIN, IT HAS REPLACED ALL THE OBJECTS WITH FRAMES WITH AN "X" AND IN THE 3D VIEW EVERYTHING IS LIKE GEOMETRIC FIGURES. ANYONE KNOWS THE REASON? THANKS A LOT |
| Posted by hansmex at Feb 25, 2021, 9:13:58 AM |
Re: THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...) Did you move the design to another directory? Update your computer? Changed the directory structure? Aside... which OS do you use, which version of SH3D? H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by HABITALIA at Feb 25, 2021, 10:22:01 AM |
Re: THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...) Good morning: I did nothing. I even open another file that I use from the same work and it comes out perfectly. The system is windows 10. It only happens to me in this file. Thanks |
| Posted by Puybaret at Feb 25, 2021, 10:49:57 AM |
Re: THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...) Your file might be damaged. Sent it to me, I'll try to understand the problem and fix it if possible. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 10:24:43 AM |
