Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: d value in .mtl can be edited in sh3d |
| Print at Sep 29, 2026, 5:17:56 PM | |
| Posted by AlbertKakiay at Feb 25, 2021, 4:22:10 PM |
d value in .mtl can be edited in sh3d For developer, to add function for editing d value in mtl, from editing furniture material. So can adjust glass transparancy without creating new object file or changes existing .mtl file. |
| Posted by Puybaret at Feb 26, 2021, 10:08:07 AM |
Re: d value in .mtl can be edited in sh3d If you want to make a color transparent, you can replace its material by a half transparent texture in Materials modification dialog box. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by AlbertKakiay at Mar 2, 2021, 1:49:22 AM |
Re: d value in .mtl can be edited in sh3d Hi Puybaret, Thanks for your response, I dont really understand, can I have example to create half transparent texture? |
| Posted by Gildaniel at Mar 2, 2021, 10:32:04 AM |
Re: d value in .mtl can be edited in sh3d Is there half transparent texture in Materials???? |
| Posted by Puybaret at Mar 2, 2021, 9:40:57 PM |
Re: d value in .mtl can be edited in sh3d Import as a texture the half transparent PNG attached to this post and use it in the Material dialog box to replace the material you want tansparent. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by AlbertKakiay at Mar 3, 2021, 8:45:15 PM |
Re: d value in .mtl can be edited in sh3d Thanks, I understand now. But, what I am asking is to make it easy for user to have transparant object model (g ...in object), from dialogs box (model material editor). ![]() |
| Posted by AlbertKakiay at Mar 3, 2021, 8:46:55 PM |
Re: d value in .mtl can be edited in sh3d https://www.mediafire.com/view/yvriz65xw8p17p6/Penjelasan_Akhir.jpg/file |
| Posted by AlbertKakiay at Mar 3, 2021, 9:02:51 PM |
Re: d value in .mtl can be edited in sh3d this method can be used also for Mirror, and Open hinge. Without changing obj file. User can interacts with this dialog box easly. |
Current timezone is GMT Sep 29, 2026, 5:17:56 PM |
