Print at Oct 5, 2026, 7:53:38 AM
Posted by noise694 at Mar 1, 2021, 3:35:43 PM
How can i remove text from my house?
Hi, im new at sweet home 3d, i added a text to my house and now i can´t remove it. Can someone help pls?
Posted by Puybaret at Mar 2, 2021, 9:47:24 PM
Re: How can i remove text from my house?
Did you try to click on it to select it and choose Edit > Delete menu item?
Posted by Rickster55 at May 16, 2024, 11:42:29 PM
I`m having the same problem. I tried clicking on the text, but nothing happens. It`s like there`s no object there. I even tried `Select All` which selects all the object, but no text.
Posted by Puybaret at May 17, 2024, 8:23:02 AM
Maybe it’s the name of a piece of furniture in which case you should unselect Display name in plan check box in its modification dialog box.
Posted by MarioSambol at Jan 17, 2025, 7:17:05 PM
It sounds stupid if the text is in a locked level, if you use them
Posted by MarioSambol at Jan 21, 2025, 12:37:28 AM
Text is always on the base plan level. If the base plan is locked, the text cannot be selected. Unlock the base plan and then it is possible to select and delete the text. If you opened the furniture properties by double-clicking on the object, deselect the enabled option to show the name of the object.
