Print at Oct 6, 2026, 8:11:28 AM
Posted by snmavronis at Mar 9, 2021, 12:34:01 AM
Levels Elevation Change
In the Modify Level dialog box if I change the 3 level's elevations so that the basement is 0' elevation and adjusted the other 2 levels relative to that, do each item's elevations within each level adjust accordingly so everything looks the same as before? I want to raise the entire house so I can make the proper landscape outside that slopes away from the house, because ground level is several feet below the main level elevation.
Steve N Mavronis - Retired PC Tech
Posted by Puybaret at Mar 9, 2021, 2:41:11 PM
Re: Levels Elevation Change
If you just want to raise the whole design, you should add the same value to the elevation of each level.
Posted by snmavronis at Mar 9, 2021, 3:07:41 PM
For example then I should just add 7’9 7/8” to each level.
Posted by Puybaret at Mar 9, 2021, 3:52:39 PM
Yes, just add 7’9 7/8” in your case.
Anyway, keep in mind that Sweet Home 3D proposes 2 guardrails when you make an error: undo and reloading the current home without saving it wink
Posted by snmavronis at Mar 9, 2021, 5:54:18 PM
Yes the undo feature is quite generous.
