Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Start with builder's floor plans |
| Print at Oct 12, 2026, 3:19:45 PM | |
| Posted by SH25414 at Mar 9, 2021, 6:07:26 PM |
Start with builder's floor plans I want to begin with a builder's floor plans which I have saved on my computer. The floor plan is one story, is totally complete, no walls need to be drawn, no doors need to be drawn, all rooms and closets are in place including the garage. My primary objective is to 1) see the plans in 3D; 2) see plan dimensions in ft (imperial); 3) be able to place our own furniture in the floor plans, i.e. measure our existing furniture and place the furniture throughout the floor plan. 4) be able to pick various floor styles, carpet/tile. Thank you Philip Collins |
| Posted by Puybaret at Mar 10, 2021, 3:44:57 PM |
Re: Start with builder's floor plans Maybe you should user's guide, it explains pretty much everything you look for. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kte6599566 at Apr 4, 2021, 11:06:15 PM |
Re: Start with builder's floor plans I'm also trying to do the same thing. I've read the users guide, imported the plans....the scaling i'm having issues with. No matter what measurements are selected, it loads like .1 of an inch. It's unworkable. What am I doing wrong? |
| Posted by Puybaret at Apr 5, 2021, 7:53:17 AM |
Re: Start with builder's floor plans You probably entered a wrong size during the second step of the Import background image wizard. The entered value must match the size of the line drawn below in the real life, not its size at screen or on the paper you scanned. If the current unit is centimeter or inch, this value will be probably much larger than 100. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 12, 2026, 3:19:45 PM |
