Print at Oct 6, 2026, 4:56:56 AM
Posted by reddy.shyam at Apr 15, 2021, 4:30:56 PM
Help needed to change java max heap size
Can someone help me with this please? I have seen FAQS but adding -Xmx in ini file but seems no effect on v6.5. I am on Windows10 Pro 64bit 20H2 latest.
Posted by reddy.shyam at Apr 15, 2021, 4:33:28 PM
Re: Help needed to change java max heap size
Sorry, the post was incomplete. I have 16GB of RAM but even changing requirement to -Xmx6g doesnot have any effect. It still uses only 2GB of ram though I have more than 50% free of 16GB
Posted by Puybaret at Apr 15, 2021, 5:14:27 PM
Are you sure your file is named SweetHome3D.l4j.ini and not SweetHome3D.l4j.ini.txt?
Posted by reddy.shyam at Apr 15, 2021, 5:55:34 PM
Hi Emmanuel,
Thanks for looking into it. yes, its definitely .ini file.
Posted by reddy.shyam at Apr 15, 2021, 6:09:13 PM
Hi Emmanuel,
Just checked, changed from 6GB to 4GB and now it is using 3GB instead of 2. Is it OS dependent?
