Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Insert a sink in a cabinet |
| Print at Oct 10, 2026, 6:17:57 PM | |
| Posted by crackwood01 at Apr 21, 2021, 12:32:18 PM |
Insert a sink in a cabinet Hi Forum! I've been searching for a way to insert a sink into a cabinet, and still can't figure it out, i know that with SH3D you have to be creative to achieve some things. Anybody as an idea? Let's say i need to insert a sink into this cabinet: ![]() |
| Posted by hansmex at Apr 21, 2021, 3:19:31 PM |
Re: Insert a sink in a cabinet - make the top invisible - place the sink - design a new top with a hole in it & place it - design the new top by drawing a room with a hole, then export-import it as furniture H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by crackwood01 at Apr 21, 2021, 3:31:06 PM |
Re: Insert a sink in a cabinet Ok thanks for this H. Now let's say i can't make the material invisible because it's the same material .. any ideas? |
| Posted by snmavronis at Apr 22, 2021, 12:15:07 AM |
Re: Insert a sink in a cabinet Just make your countertop using a floor the specified thickness like this and place as desired. ![]() ![]() ---------------------------------------- Steve N Mavronis - Retired PC Tech |
| Posted by KevinKillion at May 6, 2021, 5:01:25 PM |
Re: Insert a sink in a cabinet I'd welcome your advice! "make the top invisible" - how do you do that? I don't see any options to change *part* of a furniture item. "design the new top by drawing a room with a hole" - how do you put a hole into the room? "export-import it as furniture" - Yay, I figured out this one, but for benefit of others this seems to do the job: Make a room and (still in the 2D view) select it, 3D View>Export to OBJ, Furniture>Import Furniture. However :( my new object created that way has no thickness. I can change the elevation off the floor, but changing the "height" seems to have no effect, it still has no thickness. Suggestions? Thank you! |
| Posted by crackwood01 at May 8, 2021, 1:01:40 AM |
Re: Insert a sink in a cabinet thanks |
Current timezone is GMT Oct 10, 2026, 6:17:57 PM |
