Print at Oct 3, 2026, 11:53:15 AM
Posted by AHuk at May 24, 2021, 5:51:49 PM
confused   There is a problem with the program.
There is a problem with the program. After starting, it works normally for 2-3 minutes. After that, everything starts to double and glitches.
What is the problem?
Windows 10 Pro 20H2
Intel(R) Core(TM) i5-10600K CPU @ 4.10GHz
DDR 4 - 16,0Gb
NVIDIA GeForce GTX 1060 6GB
Posted by Puybaret at May 24, 2021, 8:28:09 PM
Re: There is a problem with the program.
Depending on your system, turn off Nahimic service or MSI afterburner / Riva Turner / Discord / NVidia Experience monitoring display software.
Posted by AHuk at May 27, 2021, 9:34:23 PM
Deleted NVidia Experience - didn't help. The problem persisted. (
Posted by myhomemyrules at May 29, 2021, 8:25:44 PM
I have the same problem, my graphics's a MSI. If I keep using the program, it eventually crashes into a "Sweet Home 3D will exit now because of a fatal error in the 3D rendering system of your computer." I've tried all solutions in the FAQ page.
I have no problem with other java programs.
Posted by AHuk at May 29, 2021, 8:42:21 PM
Disconnected another service - "Nahimic service" it all worked. Thank you!
