Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3d preview super slow |
| Print at Sep 27, 2026, 9:30:02 PM | |
| Posted by MT1976 at Jun 3, 2021, 5:16:52 PM |
3d preview super slow Hi all, I have used SH3d until a couple of weeks ago and everithing was perfect. After some windows 10 update, suddenly 3d preview became terribly slow, it freeze every time i try to use it. I ve tried to uninstall and re-instal with "free version available at SourceForge.net " and "Launch Sweet Home 3D with Java Web Start". nothing both version does not work anymore. any ideas how to solve it? |
| Posted by Puybaret at Jun 5, 2021, 9:18:12 AM |
Re: 3d preview super slow Maybe you imported a 3D model that slows down the program. Could you check how the demos available in the Gallery or in File > New from demo menu item behave? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by HIdayatsyah at Aug 4, 2021, 9:40:11 PM |
Re: 3d preview super slow I manage to make my rendering process a bit faster by adding the "Javaw.exe" as a "game" into my AMD Radeon Setting. I copy this steps from how the kids make their ROBLOX Game run faster/smoother. Steps are: 1. Open the AMD Radeon Software setting 2. Add Game 3. Browse for location of Javaw.exe (mine is C:\Program Files\Sweet Home 3D\runtime\bin\Javaw.exe) 4. Add JavaW.exe as a game. After adding it, I set for AMD to override the application setting on several aspects such as anti-aliasing and enable Surface Format Optimization. You may try some other combination. I also tried to to modified windows graphics setting and add Javaw.exe /SweetHome3D.exe set as "high performance", but seems no effect by that setting. I think this scheme might be works as well for other video cards. But, please be careful and monitor the temperature of the PC/Processor at trial. I work in a room with 25-30 C, and manage the graphic processor temperature around 60-70 C while running rendering process, and the usage of graphic processor usage is a bit higher (from 4% to 9%) Appreciate advise from experts here whether this step is safe for my notebook. So far, SH3D application is running well in my notebook. ~Day Mobile AMD Ryuzen7-Radeon Graphic 16MB RAM, and cups of coffee |
| Posted by edusson at Jun 23, 2022, 12:26:05 AM |
Re: 3d preview super slow Realize it's an old thread but I thought it may help someone. Got similar issue, lagging on the 3D view (and even when drawing in the 2D). If I removed the floor texture it did speed up. But the unexpected thing that seems to affect it is if I display the 3D view in separate window and put that window on my second monitor. That creates a lag of 1s... Cheers |
| Posted by hanabi at Jul 14, 2022, 8:47:04 AM |
Re: 3d preview super slow I manage to make my rendering process a bit faster by adding the "Javaw.exe" as a "game" into my AMD Radeon Setting. Steps are: 1. Open the AMD Radeon Software setting 2. Add Game 3. Browse for location of Javaw.exe (mine is C:\Program Files\Sweet Home 3D\runtime\bin\Javaw.exe) 4. Add JavaW.exe as a game. Thank you so much for this; you are a lifesaver! This worked perfectly for my laptop's NVidia graphics card, and I now have a super-fast 3D view that updates in less than a second and can be smoothly panned with the mouse (updates normally took around 15 seconds previously). |
| Posted by Kyle2k at Aug 4, 2022, 2:50:23 PM |
| Posted by Kyle2k at Aug 5, 2022, 12:42:43 AM |
Re: 3d preview super slow I posted my last message in error, my reply was inconclusive. I quoted the colleague above asking if someone could help me with a tutorial on how to optimize the SH3D to get the most out of my RTX 2070 Super video card, don't know how to do it. No criticisms for this wonderful software, but it's very frustrating to have a high end PC and browse with a very low FPS rate in 3d view. Hugs and thanks! |
| Posted by hanabi at Nov 6, 2022, 3:31:41 AM |
Re: 3d preview super slow Kyle2k, For an NVidia card and assuming your OS is set up the same as mine:
| Posted by Solar_Honie at Feb 10, 2024, 11:39:11 AM |
Hi there! I use NVidia Geforce GTX 1660, and the red line is no where to be found on my NVidia Control Panel. Could you please help me? |
Current timezone is GMT Sep 27, 2026, 9:30:02 PM |
