Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Would like to import DXF furniture files that I have |
| Print at Sep 26, 2026, 5:46:02 PM | |
| Posted by jloveless at Oct 17, 2009, 6:30:24 PM |
Would like to import DXF furniture files that I have I have a bunch of purchased (licensed) furniture files in DXF format. Is there a way to import them into the SH3D libraries or to use them in some other way? I would hate to lose them. Thanks. Great program! |
| Posted by Puybaret at Oct 17, 2009, 7:05:33 PM |
Re: Would like to import DXF furniture files that I have Try to import your DXF files in Blender and export them at Wavefront OBJ format, and then import OBJ files in Sweet Home 3D. If you never used Blender, don't forget to select the objects you want to export and take care about the various options in export dialog: Generally, I check Normals, Object Groups, Material Groups and Copy Images. Please tell us how it worked. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by boltonbrooksy at Apr 9, 2010, 11:23:47 AM |
Re: Would like to import DXF furniture files that I have Hi I'm looking to export a file created by my Client so I can use it in Vectorworks 2008, I read your response about importing and wondered whether it would work in reverse for export. Cheers Chris |
| Posted by Puybaret at Apr 9, 2010, 12:32:31 PM |
Re: Would like to import DXF furniture files that I have At what format is the file created by your client? If it's a SH3D file, you can export it to OBJ format with Sweet Home 3D and import the OBJ file or transform it to an other format with Blender or an other program. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by boltonbrooksy at Apr 10, 2010, 1:16:51 PM |
Re: Would like to import DXF furniture files that I have brilliant I'll give it a go....... thanks |
| Posted by nchandol at Mar 8, 2011, 7:35:42 AM |
Re: Would like to import DXF furniture files that I have Hi everybody, i would like to ask which is the easiest way to import the obj files into blender? For example if I had designed a room in SweetHome3D and I had it exported in .obj, then how can i import it into blender so that it can recognize all the furnitures etc i had in my project? Thank you in advance! :) |
| Posted by orducom1 at May 21, 2013, 4:42:16 PM |
Re: Would like to import DXF furniture files that I have hi guys, I search how can I import *.obj file into SW3D 3.7 I don't find menu "Import from OBJ format ...". could you give me some help ? thx by advance :) |
| Posted by Puybaret at May 21, 2013, 5:01:35 PM |
Re: Would like to import DXF furniture files that I have Plese read the help about importing furniture included with the program. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 26, 2026, 5:46:02 PM |
