Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Change 'Size' Direction of Arrow in Selected-Object Popup Control |
| Print at Oct 3, 2026, 2:04:45 PM | |
| Posted by paepcke at Jul 21, 2021, 7:26:15 PM |
Change 'Size' Direction of Arrow in Selected-Object Popup Control After selecting an object, its highlighted shape shows controls at its edges, such as rotation, resizing, and an arrow to change one dimension's size. I would like to change the size that the arrow control modifies. Sometimes I want that to be the width, other times the depth, elevation, etc. Can I control which size the arrow controls? Same for the rotations. There are (often) two of those. I *think* those are always 'Z', plus whichever axis is selected in the furniture modification window? This program has made me happy for almost a week now, building my house. |
| Posted by Puybaret at Jul 21, 2021, 8:30:14 PM |
Re: Change 'Size' Direction of Arrow in Selected-Object Popup Control When the shift key is pressed while resizing a piece of furniture, the piece is proportionally resized along all dimensions. When the Ctrl key (option / alt key under macOS) is pressed while resizing a piece of furniture, the piece is resized along X or Y. Rotating a piece around a horizontal axis must be initiated from the Furniture modification dialog, then its height indicator is replaced by a rotation indicator which lets you change the rotation angle. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 2:04:45 PM |
