Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Changing the Floor size..? |
| Print at Sep 27, 2026, 8:28:18 AM | |
| Posted by drag at Oct 17, 2009, 10:11:22 PM |
Changing the Floor size..?When I Create Photo I see my ground texture extend all the way to the horizon... How do I either adjust the Horizon or force the ground texture to match that of my floor plan? I also would like to put a photo of my view from my apartment out the window but when I import it as a texture. The bottom of the image is displayed at the horizon... So knowing how to adjust the horizon would be helpful too... I couldn't find anything in the help or the forums on this. Thanks! |
| Posted by Puybaret at Oct 19, 2009, 1:35:43 PM |
Re: Changing the Floor size..? You have to create a room and change its floor texture. If you want a surface that covers all your home, double-click on one of its walls when the create room tool is selected. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by drag at Oct 19, 2009, 11:35:29 PM |
Re: Changing the Floor size..? Great.. thank you! Can you tell me about the horizon as well? I'd like to have the view of buildings out the apartment window... |
| Posted by Puybaret at Oct 20, 2009, 8:05:13 AM |
Re: Changing the Floor size..? I think the best tip to get a nice horizon is to apply a photo on a dummy wall at the exterior. For example, to create the following image I created a wall at the exterior of the room and changed the side texture of the wall with an imported photo. When I imported that photo as a texture, I set the same height as the one of the wall (250 cm). A last tip : to ensure the exterior view is correctly enlighted, I put a dummy ceiling close to it (Sweet Home 3D creates a new light in the middle of each ceiling). I created the previous image with the HotelRoom.sh3d file joined to this message. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 8:28:18 AM |
