Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: screen / font size to small to used |
| Print at Oct 7, 2026, 6:41:40 AM | |
| Posted by airtac at Aug 2, 2021, 4:32:55 PM |
screen / font size to small to used Running Ubuntu 20.04 and font and screen size is to small to read. I think this is system problem not your program. What do I need to change to use you program. |
| Posted by Puybaret at Aug 2, 2021, 11:55:17 PM |
Re: screen / font size to small to used Please read the FAQ Texts in the furniture catalog are not displayed correctly or icons in the toolbar appear very small on my computer. How can I fix that? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Kumaaran at Dec 1, 2021, 3:50:08 AM |
Re: screen / font size to small to used Please read the FAQ Texts in the furniture catalog are not displayed correctly or icons in the toolbar appear very small on my computer. How can I fix that? Can you please, let me know how to use the suggested method in the FAQ... that is HiDPI Java Web Start version??? |
| Posted by Puybaret at Dec 1, 2021, 11:09:45 AM |
Re: screen / font size to small to used For Linux, it's explained in the last sentence of this FAQ. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Lawrie at Apr 14, 2022, 6:03:05 AM |
Re: screen / font size to small to used I'm running Windows 10 64X on a PC I sorted this successfully: Searched C:\ drive for JAVA.EXE Results beside SweetHome logo caame up with multiple versions of JAVA.EXE, JAVAW.EXE & JAVAWS.EXE I opened each in turn and applied the following: Find java.exe you installed. - (You've just done this) Right click -> Properties Go to Compatibility tab Check Override high DPI scaling behaviour. Choose 'System' in the 'Scaling performed by:' Check 'Apply' to each in turn. Do this for all of the above 'exe' files Restart the computer Open SweetHome and I hope you find the issue resolved. I don't know if all of them needed modifying but doing so worked for me. :) :) :) Lawrie |
Current timezone is GMT Oct 7, 2026, 6:41:40 AM |
