Print at Oct 4, 2026, 9:48:57 PM
Posted by reddy.shyam at Aug 5, 2021, 9:59:21 AM
Is it possible to replace color or texture used at all places in the model?
I am trying to change colors/textures to see how it looks. In order to do so, I have to change many objects like walls, furniture etc. So was wondering if there is a plugin or an easy way out where I can say change color from x to y or change texture from x to y everywhere?
Is this possible at all?
Posted by Puybaret at Aug 6, 2021, 8:18:05 AM
Re: Is it possible to replace color or texture used at all places in the model?
You may change the colors / textures of more than one object at the same time, by selecting them (or selecting all) then choosing one of the Modify... items in the Furniture or Plan menus. Note also that Modify rooms menu item propose to change all the sides of tha walls touching the selected room(s).
You could also try Global change color plugin and General change texture plugin.
Posted by reddy.shyam at Aug 6, 2021, 8:44:51 AM
Thanks Emmanuel. You are a star and great help as always. 👌🤝🙏
I have to replace colors and textures on all levels so the plugins you suggested are just perfect for my need.
Thanks again! Have a good day!
