Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem with "Create photo function"/Internal Renderer |
| Print at Sep 29, 2026, 12:21:09 AM |
| Posted by hansmex at Oct 31, 2010, 6:52:56 AM |
Re: Problem with "Create photo function"/Internal Renderer Slo, If your problem was solved by moving the virtual visitor 2 mtr, than most probably the v.v. was in a wall ...... Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Oct 31, 2010, 12:12:15 PM |
Re: Problem with "Create photo function"/Internal Renderer I should a warning or something like that when the virtual visitor is on a wall. What's your opinion? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Oct 31, 2010, 12:31:55 PM |
Re: Problem with "Create photo function"/Internal Renderer Emmanuel, Maybe you could do something else... When magnetism is "on", windows attach themselves "inside" walls, and objects attach themselves "against" walls. Maybe it's possible to do something similar with the virtual visitor? It's either on one side of the wall, or on the other side of it. Only when you move it with the cursor keys, can you position it inside the walls. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 29, 2026, 12:21:09 AM |
