Print at Oct 7, 2026, 3:28:43 AM
Posted by MRohner at Aug 19, 2021, 8:38:44 PM
Freeze when opening a model
I can create a new model with some rooms and some standard furniture.
As long as I don't close the model, everything just works fine.
But when I close the app and reopen the model the application freezes.
So I'm not able to edit/reuse a model!
What's wrong here?
Any ideas would be extremely appreciated! Thank you so much.
My setup:
Sweet Home 3D
Version 6.6a
MacOS Big Sur 11.4
MacBook Pro 16GB RAM
Radeon Pro 560 4 GB
Posted by MRohner at Aug 20, 2021, 7:03:44 AM
Re: Freeze when opening a model
I was able to narrow done the problem:
- it occurs with V6.5 too
- it occurs when I start the application and try to open a model (any model), which I created earlier
And I found out, how to open a "old" model, but it is a bit strange:
1. Start the application
2. Save the empty model which appears when starting the application
3. Open an old model --> and the it works
So, the problem is not high priority anymore, but I don't know how to get rid of the exclamation mark. May a moderator can do it.
The question is, why can't I open a saved model just after starting the application?
Thanks.
Posted by Puybaret at Aug 20, 2021, 2:19:47 PM
Please try the special version available at
http://www.sweethome3d.com/downloads/SweetHome3D-6.6-macosx-jogl-2.3.2.dmg
which runs with an older version of JOGL.
As it can't be notarized, you'll have to launch it the first time by clicking on Sweet Home 3D icon while maintaining control key pressed and choosing Open item.
Posted by tsi at Oct 9, 2021, 6:13:01 PM
Basically the issue makes the software unusable on MacOS.
If I have any model, I cannot reopen the sh3d file any more.
The software just freezes.
MacOS 10.14.6 with the Java 17
The special version SweetHome3D-6.6-macosx-jogl-2.3.2.dmg works fine.
Posted by Puybaret at Oct 9, 2021, 6:35:57 PM
Please don’t over exaggerate the problem. Many users don’t have this problem (me included) and many people don’t import 3D models.
By the way, as far as I know, Sweet Home 3D can’t work with Java 17 yet, and it’s bundled with Java 15.
