Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: light power option on object |
| Print at Oct 3, 2026, 9:30:24 AM | |
| Posted by subia75 at Aug 30, 2021, 11:00:08 AM |
light power option on object Hi I'm new to this program but I like it and am enjoying recreating my home. I drew things to learn, and I also downloaded items. The problem is with the lights, when I import an object I don't find the "light power%" item in the properties. I would have liked to attach a scren of an object present in SH3D and one imported by me but I am unable to attach images. How can I do to have this entry in the object properties? Thank you |
| Posted by Puybaret at Aug 31, 2021, 2:38:02 PM |
Re: light power option on object It's more complicated than just setting a light power value. You'll have to create a furniture library and change some special properties used to set light location and power. You could also simply add one of the 8 light sources found in the catalog to your plan and place it within the 3D model you imported. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 9:30:24 AM |
