Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Program has been freezing almost every time I try to use it for years now |
| Print at Oct 5, 2026, 4:34:54 PM | |
| Posted by jschlosser at Sep 6, 2021, 10:22:10 PM |
Program has been freezing almost every time I try to use it for years now Seriously. Over the span of 4 of years at least. I have even upgraded computers in that period and the behavior persists. I am currently running Sweet Home 3d 6.6, Java 8 Update 301, 64-bit. I had the same trouble running under 32-bit. If you could guarantee that the issue would be resolved by going to the paid version, I would do that. Gladly. I am using a Dell G5000, 32 GB, NVIDIA GeForce RTX 2060 running under Windows 10 Pro. Previously I have had issues running different Dell PCs under Windows XP Pro and Windows 10 Pro but without the separate graphics card. I thought upgrading my graphics would help. This is the behavior: I open an existing home. Sometimes the 3d view opens in a different window, sometimes within the same window. It doesn't matter which I am in. I can usually do a couple of things before it hangs up. I have to use the task manager to close. I just tried it making a simple small room with 3 pieces of furniture and even that is hanging, so file size doesn't appear to be the issue. I love this program but don't want to have to relearn some other program. Can you help me? |
| Posted by Puybaret at Sep 8, 2021, 1:56:24 PM |
Re: Program has been freezing almost every time I try to use it for years now Did you try older versions like 6.4 or 5.7? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 5, 2026, 4:34:54 PM |
