Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: An arch roof |
| Print at Oct 8, 2026, 10:38:37 AM | |
| Posted by TM007 at Sep 22, 2021, 7:58:26 AM |
An arch roof Hello. Newbie asks that how I do an arch roof to a room? Like cave ceiling? We have some 3m width room and according to test (as a normal wall) arch extent is 118 degrees. In other words the arc is bent some 80 cm. Rgs, TM007 |
| Posted by hansmex at Sep 22, 2021, 3:02:21 PM |
Re: An arch roof - Draw a wall of the length needed (3 mtr) - Use Modify walls - Arc extent and set it to 118 degrees - Apply texture(s) on inside and/or outside (rotate 90 degrees if needed) - Export selection - Import and rotate 90 degrees H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by TM007 at Sep 22, 2021, 4:12:48 PM |
Re: An arch roof Hello hansmex. Thanks about guiding. I followed maybe wrong Your instructions because I couldn't "flip" the arch to top of the room. I try harder. Anyway nice to know that it is easy to make own library elements! Nice feature. |
| Posted by TM007 at Sep 22, 2021, 4:25:09 PM |
Re: An arch roof This is missing in Mod walls : "(rotate 90 degrees if needed) |
| Posted by hansmex at Sep 22, 2021, 5:17:49 PM |
Re: An arch roof Read the user guide on how to export part of a model, and in how to import and rotate it. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 8, 2026, 10:38:37 AM |
