Print at Oct 2, 2026, 8:47:30 AM
Posted by wyllyjon at Sep 23, 2021, 8:31:21 PM
Problème d'installation sur Ubuntu 18.04
Salut à tous !
J'essaie de lancer, sans succès, Sweet Home 6.6 sur Ubuntu 18.04.
J'ai l'erreur suivante:
com.jogamp.opengl.GLException: J3D-Renderer-1: Error making temp context(1) current: display 0x7fb2ac15b430, context 0x7fb2ac309fd8, drawable X11OnscreenGLXDrawable[Realized true,
Factory jogamp.opengl.x11.glx.X11GLXDrawableFactory@638420f5,
Handle 0x360009b,
Surface JAWTWindow[0xac2aaf4][JVM version: 1.8.0_202 (1.8.0 update 202)
JAWT version: 0x10004, CA_LAYER: false, isLayeredSurface false, bounds [ 0 / 0 813 x 370 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], pixelScale 1.0x1.0, shallUseOffscreenLayer false, isOffscreenLayerSurface false, attachedSurfaceLayer 0x0, windowHandle 0x360009b, surfaceHandle 0x360009b, bounds [ 0 / 0 813 x 370 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], window [0/0 813x370], pixels[scale 1.0, 1.0 -> 813x370], visible true, lockedExt false,
config AWTGraphicsConfiguration[AWTGraphicsScreen[AWTGraphicsDevice[type .awt, connection :0.0, unitID 0, awtDevice X11GraphicsDevice[screen=0], handle 0x0], idx 0],
chosen GLCaps[glx vid 0xaa, fbc 0x191: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
X11GraphicsConfig[dev=X11GraphicsDevice[screen=0],vis=0xaa],
encapsulated X11GLXGraphicsConfiguration[X11GraphicsScreen[X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x7fb2ac15b430, owner true, JAWTToolkitLock[obj 0x25464235, isOwner true, <21774799, 63b658ca>[count 1, qsz 0, owner <J3D-Renderer-1>]]], idx 0], visualID 0xaa, fbConfigID 0x191,
chosen GLCaps[glx vid 0xaa, fbc 0x191: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]]]],
awtComponent com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas2,0,0,813x370],
surfaceLock <46ce58d6, 7741718a>[count 1, qsz 0, owner <J3D-Renderer-1>]]]
at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:393)
at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:770)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:653)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:591)
at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6411)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4612)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2386)
at javax.media.j3d.Renderer.doWork(Renderer.java:881)
at javax.media.j3d.J3dThread.run(J3dThread.java:271)
Error in Java 3D : 3 Renderer: Error creating Canvas3D graphics contextX11Util.Display: Shutdown (JVM shutdown: true, open (no close attempt): 2/2, reusable (open, marked uncloseable): 0, pending (open in creation order): 2)
X11Util: Open X11 Display Connections: 2
X11Util: Open[0]: NamedX11Display[:0, 0x7fb2ac032300, refCount 1, unCloseable false]
X11Util: Open[1]: NamedX11Display[:0, 0x7fb2ac15b430, refCount 1, unCloseable false]
Est-ce que ça parle à quelqu'un ??
Merci et bonne soirée !
Posted by Puybaret at Sep 24, 2021, 9:47:16 AM
Re: Problème d'installation sur Ubuntu 18.04
Est-ce que vous avez aussi essayé de lancer Sweet Home 3D avec le script SweetHome3D-Java3D-1_5_2 qui se trouve dans le même dossier ?
