Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Upgrade from 6.2 to 6.6 |
| Print at Oct 4, 2026, 1:59:03 PM | |
| Posted by RegalHI at Oct 22, 2021, 6:03:38 PM |
Upgrade from 6.2 to 6.6 Hardware Linux Mint 20.1 Java 11.0.11 16Gb Ram I have SweetHome3D version 6.2. I want to upgrade to version 6.6. I have downloaded the file from the SweetHome3D webpage. It runs fine on my computer just fine when I execute the file from the extracted file location. But it does not install on my computer. I tried erasing the old version first to see if that was an issue but it wasn't. My Software manager will only install version 6.2. What am I missing? The install instructions on the SweetHome3D webpage are vague and unhelpful. |
| Posted by UbuntuBirdy at Nov 5, 2021, 4:34:58 PM |
Re: Upgrade from 6.2 to 6.6 You do not need to install the version you have downloaded from the website. I'm working with Ubuntu and Mint should be very similar to Ubuntu. So, copy the downloaded folder to where you want it (mine is in /usr/share/SweetHome3D-6.6). Then go to /home/"your_username"/.local/share/applications and create a file called "SweetHome3D.desktop". And this file should contain the following lines: [Desktop Entry]Edit: of course you can edit the german parts in these lines to your preferred language. ---------------------------------------- Pascal SH3D 6.6 / Ubuntu 22.04 (Mainline-Kernel) / Radeon RX580 / Ryzen 7 5800x |
| Posted by bert.struik at Mar 8, 2023, 6:42:02 AM |
Re: Upgrade from 6.2 to 6.6 Additional instructions. 1. Once the desktop file is created the program can be launched from the applications launcher. And when program is open the launch icon can be added to the favourites. I did not know that about .desktop files. 2. To add a plugin to the program Go to /Home/.eteks and create a directory called the program name you used for SweetHome3D. Then in that directory create a directory called: plugins Put a copy of the plugin file in the plugins directory and extract it there (double click on file name top open and extract). Extract to the plugins directory. Launch the program (and if the plugin works with that version) and the plugin will appear in the Tools menu option. |
| Posted by bert.struik at Mar 29, 2023, 6:52:17 PM |
Re: Upgrade from 6.2 to 6.6 RE adding plug-in I gave wrong instructions. Instead: Put the downloaded plugin file in the directory /.etecs/sweethome3d/plugins Create plugins directory if it did not exist. Do not extract. |
| Posted by Puybaret at Mar 31, 2023, 8:51:44 AM |
Re: Upgrade from 6.2 to 6.6 The folder where plug-ins are stored under Linux is .eteks/sweethome3d/plugins in your home folder, .eteks being spelled with a k, not a c. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 4, 2026, 1:59:03 PM |
