Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Photo creation problem |
| Print at Sep 30, 2026, 11:07:07 AM | |
| Posted by frevandonanet at Oct 31, 2009, 1:37:16 PM |
Photo creation problem Hi, I've just downloaded SweetHome and started to play around with it. Everything worked fine until I tried to create photos. I'm able to create the photos with quality 0 or 1, but when I try photos with quality 2 or 3 I get a black figure. I'm using ubuntu 9.04. I tried to run SweetHome in 3 different ways (with java webstart, with the download installer and with the jar file) and always got the same results. Any help will be welcomed. Thanks. Alexandre |
| Posted by frevandonanet at Oct 31, 2009, 1:49:55 PM |
Re: Photo creation problem By the way, the problem only appears when I use virtual view. With the aerial view, it works fine. |
| Posted by califdon at Oct 31, 2009, 6:53:01 PM |
Re: Photo creation problem I'm having a similar, but more severe problem with Sweet Home 3D on WIndows XP. I cannot create a photo at all. For about 1 second, there is an activity status indicator, then a small red X in the center of the frame. I do not have a video card, just the onboard video controller. I am very pleased with the software, but it would really be nice to be able to create photos. |
| Posted by califdon at Nov 1, 2009, 12:34:04 AM |
Re: Photo creation problem Update: I can indeed create a 3D photo, but only at "best" quality setting (which is OK). Anything less than that, it will not work. Seems like the same problem in Ubuntu described in the original post. |
| Posted by carolaclavo at Nov 6, 2009, 2:57:03 PM |
Re: Photo creation problem Hello, I'm also newbie, just downloaded the application a few days ago and it's great to plan my next move to a new flat ;) It is a GREAT application!! But when I want to save a photo, I can't use highest quality, it just starts and stops after rendering a few % In my case I'm using a Mac and the latest version. Thanks for any help :) |
| Posted by carolaclavo at Nov 6, 2009, 2:59:36 PM |
Re: Photo creation problem This is what I get. It starts working but after rendering 11 little squares or portions, it gets stuck. [URL=http://img689.imageshack.us/i/capturadepantalla200911b.png/][IMG]http://img689.imageshack.us/img689/1346/capturadepantalla200911b.th.png[/IMG][/URL] |
| Posted by Puybaret at Nov 7, 2009, 5:27:50 PM |
Re: Photo creation problem Your image ![]() makes me think about this bug. Miserably, it's not fixed yet. Could you try to remove the objects under the green or red squares, and check if rendering still fails? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by carolaclavo at Nov 7, 2009, 9:46:21 PM |
Re: Photo creation problem Hi there! I made a new project with no furnitures at all, just windows (only one in the photo to be created) and the rendering still failed. It fails in two fashions; one of them while working, with red or green squares displayed as before, or in the other style, showing a red 'x' like the image was missing. Thanks! |
| Posted by Puybaret at Nov 9, 2009, 7:43:08 PM |
Re: Photo creation problem Please try this: 1. Launch Console program found in /Applications/Utilities folder and click on Clear display. 2. Launch Sweet Home 3D and try to create a photo. 3. Console program should display some new text that will help me a lot to guess your issue. Please select that text and copy paste it in a comment here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MarcSc at Nov 9, 2009, 9:23:06 PM |
Re: Photo creation problem Just a silly question, does the partition have enough free space? Perhaps tmp is full, or the path Sweet Home 3D is using for output is full? |
| Posted by Puybaret at Nov 10, 2009, 5:20:32 PM |
Re: Photo creation problem Once photo creation is started, Sweet Home 3D doesn't use tmp disk space (it may require swap space because it grows in memory but swap is managed by the system). Please, post here the Console messages if you can ; it will give me really some information. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Nov 16, 2009, 8:49:04 PM |
Re: Photo creation problem I discovered with a French user that photo rendering may fail if two walls are superimposed on each other. Please, check whether it's your configuration or not. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by LUH3417 at Jan 23, 2010, 7:20:18 PM |
Re: Photo creation problemHi, I have the same problem underWin XP. Sometime a restart will help. But now with a scene with many objects rendering/photo does not work at all. I tried to find console program but I can't find it. There is no application directory. best reagrds lucas |
| Posted by kamilamonica at Jan 27, 2010, 6:00:28 PM |
Re: Photo creation problem Hi there! I made a new project with no furnitures at all, just windows (only one in the photo to be created) and the rendering still failed. It fails in two fashions; one of them while working, with red or green squares displayed as before, or in the other style, showing a red 'x' like the image was missing. Thanks! From Puybaret Re: Photo creation problem Please try this: 1. Launch Console program found in /Applications/Utilities folder and click on Clear display. 2. Launch Sweet Home 3D and try to create a photo. 3. Console program should display some new text that will help me a lot to guess your issue. Please select that text and copy paste it in a comment here. Hi Puybaret, Here you are, the errors: 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] Exception in thread "Thread-7" 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] java.lang.ArrayIndexOutOfBoundsException: 64 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.accel.BoundingIntervalHierarchy.intersect(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.Scene.trace(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceReflection(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceReflection(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.ShinyDiffuseShader.getRadiance(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.getRadiance(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.Scene.getRadiance(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.computeSubPixel(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.refineSamples(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.renderBucket(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.access$300(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer$BucketThread.run(Unknown Source) 10-01-27 18:41:07 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer$BucketThread.run(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] Exception in thread "Thread-6" java.lang.ArrayIndexOutOfBoundsException: 64 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.accel.BoundingIntervalHierarchy.intersect(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.Scene.trace(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceReflection(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceReflection(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.ShinyDiffuseShader.getRadiance(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.shadeHit(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceRefraction(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceRefraction(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.GlassShader.getRadiance(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.shadeHit(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceReflection(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceReflection(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.GlassShader.getRadiance(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.shadeHit(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceReflection(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceReflection(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.GlassShader.getRadiance(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.shadeHit(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceRefraction(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceRefraction(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.GlassShader.getRadiance(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.shadeHit(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceRefraction(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceRefraction(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.GlassShader.getRadiance(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.shadeHit(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.traceRefraction(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.ShadingState.traceRefraction(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.shader.GlassShader.getRadiance(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.LightServer.getRadiance(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.Scene.getRadiance(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.computeSubPixel(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.refineSamples(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.refineSamples(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.refineSamples(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.renderBucket(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer.access$300(Unknown Source) 10-01-27 18:46:22 [0x0-0x20020].com.eteks.sweethome3d.SweetHome3D[1628] at org.sunflow.core.renderer.BucketRenderer$BucketThread.run(Unknown Source) Does anyone know how to avoid this issue? To me it looks like the error is given by 3D models downloaded from unknown sources. Regards Kamila |
| Posted by Puybaret at Nov 14, 2010, 6:03:33 PM |
Re: Photo creation problem For information, this bug was fixed in version 2.6. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 11:07:07 AM |
