Print at Oct 7, 2026, 3:13:39 PM
Posted by olibad at Dec 18, 2021, 3:04:01 PM
Not working at all
I experienced.. well... basically nothing, as it's not working.
1. Why is the application popping up at a random position everytime I open it? (Video Application popping up at random positions on startup)
Second, as soon as I try to actually "work" with it, everything messes up. (Video: Messing up things as soon as I do anything)
Tried 32 and 64bit versions.
Using a Windows 10 up-to-date version.
Posted by Puybaret at Dec 18, 2021, 5:32:58 PM
Re: Not working at all
1. Windows are not opened at random locations, but rather at a location where it shouldn't overlap another window when two windows are opened. Is it so important?!
2. You should probably turn off Nahimic service. See also bug #684.
Posted by olibad at Dec 18, 2021, 5:58:21 PM
Arrcording
1. Well it bothered me a lot as I wanted to record that particular part of the screen and this app randomly appearing on the screen. There were no other windows open. Whatever, more important is...
2. In your linked bug thread, someone wrote "since the bug appears only when Riva Tuner Statistics Server is running..."
So I deactivated MSI Afterburner, which includes HWInfo, which includes Riva Tuner.
Result: No more problems so far!
Thanks now I can use the program :)
