Print at Sep 30, 2026, 9:23:39 PM
Posted by Jo_Alfemo at Dec 18, 2021, 5:23:33 PM
Ceiling is not close to the walls
in a project I'm doing, the ceiling is not close to the walls. What can it be? How can I solve?
[img]https://live.staticflickr.com/65535/51754042167_78c8b13822_k.jpg[/img]Image1 by José Monteiro, no Flickr
Thanks in advance
Posted by Puybaret at Dec 18, 2021, 5:35:44 PM
Re: Ceiling is not close to the walls
You must have created more than one level and didn't set a height for the level matching the height of your walls. The height of a level is used to know the elevation of ceilings (except for the last level).
Posted by Jo_Alfemo at Dec 19, 2021, 9:08:19 AM
Hi Puybaret.
Do you mean I have to eliminate the second level and build that level again? Actually initially I just copy/paste to add the second level.
Tks for help
Posted by Puybaret at Dec 19, 2021, 4:33:34 PM
Don't delete anything, just select the first level and modify its height in the level modification dialog box.
Posted by Jo_Alfemo at Dec 19, 2021, 6:50:39 PM
Here?
[img]https://live.staticflickr.com/65535/51757334453_95c1e722d9_k.jpg[/img]Image1
Posted by Puybaret at Dec 19, 2021, 7:04:55 PM
Yes
Posted by Jo_Alfemo at Dec 20, 2021, 6:33:51 PM
Yes
Well, I solved the first floor problem. now on the second floor the roof is slanted. laughing laughing
How to solve?
Tks in advance
[img]https://live.staticflickr.com/65535/51759442483_5635213972_k.jpg[/img]Image2 by [url=https://www.flickr.com/photos/jose_monteiro/]
Posted by Puybaret at Dec 20, 2021, 6:52:40 PM
Add a dummy level, because slanted ceilings are computed only at the last level.
Posted by Jo_Alfemo at Dec 21, 2021, 5:28:13 PM
dummy level???
Posted by Puybaret at Dec 21, 2021, 5:31:30 PM
By "dummy", I meant a level that you won't actually use, but that will change the algorithm which computes ceiling at the before last level.
