Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Maybe... 3D rendering preview problem |
| Print at Sep 30, 2026, 4:41:19 PM | |
| Posted by GaelR2D2 at Dec 28, 2021, 8:02:07 PM |
Maybe... 3D rendering preview problem Hello, Sometimes when I open an house file, the levels preview (top right pane) show me all the furniture in thumbnails, instead of the objects themselves. Other times it show me the correct view. (no changing in "Preferences") I've already reinstalled the software several times, and it keeps doing that... What am I doing wrong? Thanks in advance, My Best Regards |
| Posted by Puybaret at Jan 6, 2022, 9:17:19 AM |
Re: Maybe... 3D rendering preview problem Could you share an image of this issue? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by GaelR2D2 at Jan 6, 2022, 8:41:48 PM |
Re: Maybe... 3D rendering preview problem Hello and thank you for the support, I'm showing below the prints of the problem. Other info which might be helpful: I'm using the version Sweet Home 6.3 / Java 1.8.0_202 32bit and I have extra installed for Furniture and Textures editor purposes: -Java Version 8 update 281 (build 1.8.0_281-b09) (the built-in java in the Program didn't work for me) I believe the extra Java version 8 is not the problem because I did a rollback in the Windows 7 restore points to before the Java installation and the problem remained. Usually shows this: https://www.mediafire.com/view/bfib4wjxulrqb5h/wrong_view.jpg/file After a few restarts of Sweet Home and sometimes the computer, shows the correct image, like this: https://www.mediafire.com/file/ffyo0it0sqpf9vg/right_view.jpg/file My Best Regards |
| Posted by Puybaret at Jan 7, 2022, 9:56:50 AM |
Re: Maybe... 3D rendering preview problem The ability to compute top view images depends on whether your computer is able to handle offscreen images or not, but I didn't know that it could vary overtime! As you use the 32 bit version, maybe you could try the DirectX version as explained here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 30, 2026, 4:41:19 PM |
