Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to adjust the transparency of one or several walls only, NOT ALL |
| Print at Aug 26, 2026, 10:31:10 PM | |
| Posted by titust11 at Jan 11, 2022, 5:43:14 PM |
How to adjust the transparency of one or several walls only, NOT ALL Is there a way to adjust wall transparency per wall and not only globally? |
| Posted by Daniels118 at Jan 11, 2022, 8:25:19 PM |
Re: How to adjust the transparency of one or several walls only, NOT ALL Can you explain in detail the purpose of the request? If you want a wall made of transparent glass there is a special window made of glass blocks, or you can create your own with 3D modelling software like Blender. If instead you want to hide a wall to better view inside a room you have several options:
| Posted by titust11 at Jan 12, 2022, 12:28:56 AM |
Re: How to adjust the transparency of one or several walls only, NOT ALL I created a level containing only the gravel layer that's all around the house and on a slope. I made that with walls instead of boxes and triangles. [moderated] [Note from moderator: don't hope more help if you start to be vulgar] |
| Posted by VeroniQ at Jan 12, 2022, 3:58:47 PM |
Re: How to adjust the transparency of one or several walls only, NOT ALL This article may interest you. |
Current timezone is GMT Aug 26, 2026, 10:31:10 PM |
