Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Defective autosave |
| Print at Oct 6, 2026, 1:20:07 PM | |
| Posted by KamiraHaruno at Jan 17, 2022, 8:01:45 PM |
Defective autosaveHello, I'm a Brazilian user and I have a problem with the projects I made: I have 3 projects in total, and I changed all of them today, in the late morning and early afternoon. As I was using it online, it doesn't have a save button, it's an automatic process of every 2 seconds the system saves itself. But it's been a long time since I finished changing, I waited the necessary time and decided to download the 3 projects to see the program that installs on the computer. But when I open the projects, none of them have the changes I made today. I'm afraid of losing the changes that took me a few minutes to make, so I have all 3 projects open in the browser I suggest having a save button even when we use it online |
| Posted by Puybaret at Jan 17, 2022, 9:33:05 PM |
Re: Defective autosave You might have encountered the same issue as in the bug #1075. First, be sure that the auto save is probably the best solution in a JavaScript environment where a crash with a page reload may occur at any moment when resources are missing. I see from the server logs that the exports you obtain from your 3 projects contain the last changes received by the server. But let's try to understand why the server didn't receive the last changes you made. I hope you kept the windows of your 3 projects opened (or at least one), so you can report what the content of the JavaScript console. Display it by choosing the menu item More tools > Developer tools (Ctrl+Shift+I) and select the Console tab. The Console should contain some lines stating Failed to load resource: the server responded with a status of 404 (Not Found)---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by KamiraHaruno at Jan 18, 2022, 12:42:26 AM |
Re: Defective autosave Hi, I still keep the 3 projects open and I still have the same problem of not saving what I changed - when downloading the file This is what appears in one of the projects: Uncaught ReferenceError: browser is not defined at onScriptLoad (chrome-extension://gighmmpiobklfepjocnamgkkbiglidom/adblock-onpage-icon-cs.js:172:3) at chrome-extension://gighmmpiobklfepjocnamgkkbiglidom/adblock-onpage-icon-cs.js:183:2 sweethome3d.min.js?version=6.6.4:20 Failed to load resource: the server responded with a status of 404 (Not Found) CoreTools.loadJSON @ sweethome3d.min.js?version=6.6.4:20 sweethome3d.min.js?version=6.6.4:20 Failed to load resource: the server responded with a status of 404 (Not Found) CoreTools.loadJSON @ sweethome3d.min.js?version=6.6.4:20 sweethome3d.min.js?version=6.6.4:20 Failed to load resource: the server responded with a status of 404 (Not Found) CoreTools.loadJSON @ sweethome3d.min.js?version=6.6.4:20 sweethome3d.min.js?version=6.6.4:20 Failed to load resource: the server responded with a status of 404 (Not Found) CoreTools.loadJSON @ sweethome3d.min.js?version=6.6.4:20 sweethome3d.min.js?version=6.6.4:20 Failed to load resource: the server responded with a status of 404 (Not Found) CoreTools.loadJSON @ sweethome3d.min.js?version=6.6.4:20 sweethome3d.min.js?version=6.6.4:20 Failed to load resource: the server responded with a status of 404 (Not Found) CoreTools.loadJSON @ sweethome3d.min.js?version=6.6.4:20 sweethome3d.min.js?version=6.6.4:20 Failed to load resource: the server responded with a status of 404 (Not Found) CoreTools.loadJSON @ sweethome3d.min.js?version=6.6.4:20 SweetHome3DJSOnline.jsp:2 Uncaught SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at XMLHttpRequest.<anonymous> (sweethome3d.min.js:20:2193403) |
| Posted by KamiraHaruno at Jan 18, 2022, 12:45:27 AM |
Re: Defective autosave Yes I use ad blockers but this has never happened before |
| Posted by KamiraHaruno at Jan 18, 2022, 1:42:40 AM |
Re: Defective autosave As I will need to turn off my computer now, when I turn it on tomorrow, probably the 3 tabs where the projects are will update and I will lose everything I changed today T_T |
| Posted by Puybaret at Jan 18, 2022, 8:27:30 AM |
Re: Defective autosave Unfortunately, the Console text you reported doesn't help. I hope that you'll have the patience to run more tests. If this keeps happening, I'll try to change the program to inform the user when recent changes couldn't be saved. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by KamiraHaruno at Jan 18, 2022, 11:12:02 AM |
Re: Defective autosave I just turned on my computer, and as expected, none of the 3 projects were saved, I'll have to redo everything T_T For these reasons and others, I believe that having a save button - so as not to depend only on automatic - would be another layer of security to protect our projects from some bug, like this one that is happening |
| Posted by Puybaret at Jan 18, 2022, 12:31:38 PM |
Re: Defective autosave I need more feedback before considering developing such a feature. Tracking an automatic saving operation during the last minutes didn’t happen will be easier to program. By the way, even if it’s sad that you lost some time, don’t let others think you lost all you work. From the logs records, you seem to have lost 2 hours of work at worst. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by KamiraHaruno at Jan 18, 2022, 12:47:39 PM |
Re: Defective autosave Well, what can I do... I'm redoing everything, but also including new stuff. I hope you save this time |
| Posted by Puybaret at Jan 18, 2022, 12:56:28 PM |
Re: Defective autosave Then check regularly that everything is saved by reloading the page, because Domenico Melisi reported this issue happened repeatedly in his case. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by KamiraHaruno at Jan 18, 2022, 1:25:07 PM |
Re: Defective autosave It seems that it worked (I didn't refresh the pages - I downloaded the files and opened it through the program), the last changes I made were saved |
Current timezone is GMT Oct 6, 2026, 1:20:07 PM |
