Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Sweet home 3d have a problem |
| Print at Sep 27, 2026, 5:20:35 PM | |
| Posted by iHaveStaleMemes at Feb 20, 2022, 6:10:16 PM |
Sweet home 3d have a problemhey guys i wanted to ask why sweet home dosen't use gpu for rendering instead of the cpu so like that it will go faster ... if there is a solution can someone tell me the steps to make sweet home use gpu instead of cpu ![]() |
| Posted by Puybaret at Feb 20, 2022, 11:23:54 PM |
Re: Sweet home 3d have a problem For your information, YafaRay was successfully tested with Sweet Home 3D as a second rendering engine. See https://www.sweethome3d.com/blog/2018/08/24/p...nes_performance_test.html and https://www.sweethome3d.com/blog/2020/01/31/yafaray_rendering_plug_in.html Even if it still doesn’t use GPU, I don’t have any intention to invest again a lot of time to try another rendering engine. If you have the capabilities to program a plug-in able to use another rendering engine, feel free to contribute inspiring yourself from YafaRay plug-in implementation. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by SamehRagheb at Feb 27, 2022, 8:20:31 PM |
Re: Sweet home 3d have a problem Try exporting your project as OBJ files then use Blender to make the rendering. http://www.sweethome3d.com/support/forum/viewthread_thread,7538 |
Current timezone is GMT Sep 27, 2026, 5:20:35 PM |
