Print at Sep 28, 2026, 4:06:12 AM
Posted by stef.salmon at Mar 4, 2022, 10:29:50 AM
Create 4 Story Building
Are there any videos on how to create a building with multiple floors. I'm not too worried about the inside of the building, but more interested in being able to create the look from outside, so it looks like a proper building with windows etc.
It needs to look like the building that I'm choosing to model.
Thanks in advance.
Posted by Puybaret at Mar 4, 2022, 12:11:19 PM
Re: Create 4 Story Building
Maybe you could look at the tip about designing large buildings.
Posted by stef.salmon at Mar 7, 2022, 2:31:47 PM
I checked out the 'Sweet Home Company' to see how it was put together. I noticed that each room/area had all it's furniture, doors etc, grouped together, so that when you moved a room all its equipment moved too. How is this done?
Thanks.
Posted by Puybaret at Mar 7, 2022, 3:21:19 PM
Use Furniture > Group menu item but it will group only furniture, not walls, rooms and dimension lines. Otherwise draw a selection rectangle to select all the objects you want to move (see also shortcuts here).
