Print at Oct 6, 2026, 1:14:03 PM
Posted by Sand0411 at Mar 8, 2022, 8:39:11 AM
Disable Autoupdate
We use the silent installation. Is it possible to deactivate the autoupdate option with a command within the silent installation, without doing it manually?
Posted by Puybaret at Mar 8, 2022, 2:19:00 PM
Re: Disable Autoupdate
If by autoupdate option, you mean the option in preferences that allows to check if some updates are available (it just checks and won't update the program), it's not possible without changing and recompiling the program.
Why not using the last version so this dialog box won't appear?
Posted by Sand0411 at Mar 9, 2022, 6:21:49 AM
Thanks for the information. We use a reborn-solution, so that the uses are not able to make any changes at the system, including the updates. So the dialog box only disturb.
Posted by Puybaret at Mar 9, 2022, 2:24:58 PM
I'll see if I can add this feature in a coming version.
Posted by Sand0411 at Mar 10, 2022, 5:32:19 AM
That would be great, thanks.
Posted by Puybaret at Jul 13, 2022, 10:13:38 PM
Please try the new /checkUpdatesDisabled argument I added to Windows installer in version 7.0.
Posted by Sand0411 at Nov 7, 2022, 10:36:51 AM
It works perfect - thanks!
