Print at Oct 4, 2026, 2:30:06 PM
Posted by mikedj at Mar 18, 2022, 5:12:04 PM
Imported Furniture Low Resolution in Plan View
When I import furniture created in Sketchup, it looks fine in SH3D 3D view, but is very pixelated in SH3D Plan View.
My procedure is:
- Create a solid model in Sketchup
- Export the 3D model as either .dae or .kmz
- Import furniture in SH3D
- Drag the new furniture to the plan
Sketchup model:
SH3D 3D view:
SH3D Plan view:
Note that I added the texture in SH3D, which offers a little more visual clarity, but the issue exists even without the texture.
I've also noticed a similar issue when using the "Generate 3D from rooms" plugin.
Is there a setting or settings that affect import resolutions? Or settings for the plan view resolution?
Thank you,
Posted by Puybaret at Mar 18, 2022, 5:56:40 PM
Re: Imported Furniture Low Resolution in Plan View
See the Icon size setting in preferences pane.
But keep in mind that it will apply to all icons and a higher value may require a lot of RAM to handle all icons.
Posted by mikedj at Mar 18, 2022, 6:31:54 PM
Perfect!
Thank you!
