Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Part of an obj invisible |
| Print at Sep 24, 2026, 12:08:57 AM | |
| Posted by crackwood01 at Mar 26, 2022, 12:37:11 PM |
Part of an obj invisibleHi Forum, as far as i know: everything is impossible until somebody does it. i was wondering: is there a way to "cut" a part of an obj, or something like it .. here i would like to cut a piece of roof .. i know it's not possible for the moment, but, as i see in this forum .. people are full of imagination ![]() |
| Posted by crackwood01 at Mar 26, 2022, 12:38:12 PM |
Re: Part of an obj invisible img: ![]() |
| Posted by sjb007 at Mar 26, 2022, 11:51:32 PM |
Re: Part of an obj invisible That looks like a roof created by Dorin's awesome plugin, so it is an object. SH3D is not a modelling tool in any meaningful sense. So I'm understanding right that you want the dormer to cut a hole in the main hipped section? This is not possible in SH3D. What you will have to do is select the objects, export them as an obj, import that into a modelling tool, and edit it there. I can confirm that Blender works for this, but any tool that can import and export .obj files should work. |
| Posted by Daniels118 at Mar 27, 2022, 8:25:58 AM |
Re: Part of an obj invisible If you are generating the roof using the Roof generator plugin, you can achieve this result with a trick. Just draw the roof as in the following picture: ![]() The dormer roof is just a texturized box with the proper inclination. |
| Posted by Puybaret at Mar 27, 2022, 4:12:04 PM |
Re: Part of an obj invisible Nice tip ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by crackwood01 at Mar 27, 2022, 8:54:37 PM |
Re: Part of an obj invisible Yes it was a roof generated with Dorin's masterpiece! Thanks for the tip! Suggestion: Add points in the 3d preview?, something like it would be crrraaazzzzyy THANK YOU |
| Posted by crackwood01 at Mar 28, 2022, 1:46:24 AM |
Re: Part of an obj invisible Hi Forum, i tried to cut the dormer part but couldnt manage to suceed. If i send you the file would you mind cut it for me please? also tried the Daniels118 trick .. line don't go exactly at the end of the roof .. shapes are a bit random |
| Posted by crackwood01 at Mar 28, 2022, 2:51:23 AM |
Re: Part of an obj invisible Figured something being creative thanks! |
Current timezone is GMT Sep 24, 2026, 12:08:57 AM |
