Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: New Bedroom |
| Print at Oct 1, 2026, 5:28:49 AM | |
| Posted by SARRAVAL at Apr 1, 2022, 4:48:43 PM |
New Bedroom Hello ![]() ![]() ![]() ![]() ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by Mike53 at Apr 2, 2022, 12:13:48 PM |
Re: New Bedroom Very nice SARRAVAL ![]() |
| Posted by sjb007 at Apr 2, 2022, 5:43:58 PM |
Re: New Bedroom Looks great. It is just a shame about the lighting fixtures are not casting realistic shadows. I think this might be a limitation of how the lighting works in SH3D though. For example the bedside lights should cast fans of light up and down against the backboard, instead of evenly lighting the whole board. Something more like: https://drive.google.com/file/d/1-fKmJcRgsCC0...JNi0PKdU/view?usp=sharing I hardly do any rendering in SH3D, so maybe someone more experienced could explain how to get a more realistic effect. And I'm curious... 5 doors?!?!? Does it have separate his and hers walk ins and ensuites? |
| Posted by SARRAVAL at Apr 3, 2022, 4:48:18 PM |
Re: New Bedroom Indeed, there are 2 bathrooms (Mrs and Mrs) and two dressing rooms, and an entrance door. ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by SARRAVAL at Apr 3, 2022, 4:50:56 PM |
Re: New Bedroom Thank you Mike53 ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by sjb007 at Apr 3, 2022, 6:45:30 PM |
Re: New Bedroom Indeed, there are 2 bathrooms (Mrs and Mrs) and two dressing rooms, and an entrance door. Yikes! Do you have such large areas in France? In the UK even a master bedroom in quite big houses will get a walk-in and an ensuite. Two of each is a lot. Do you intend to build this, or is this just daydreaming? |
| Posted by SARRAVAL at Apr 4, 2022, 8:53:15 AM |
Re: New Bedroom just daydreaming!---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by coldcomfort at Apr 4, 2022, 7:26:09 PM |
Re: New Bedroom When did people start day dreaming about empty rooms with curtains? |
| Posted by SARRAVAL at Apr 4, 2022, 8:12:22 PM |
Re: New Bedroom![]() ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by sjb007 at Apr 4, 2022, 11:13:40 PM |
Re: New Bedroom When did people start day dreaming about [large] empty rooms with curtains? Since being cooped up in small apartments for two years due to a pandemic? |
| Posted by SARRAVAL at Apr 5, 2022, 6:51:50 AM |
Re: New Bedroom That must be it ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by SARRAVAL at Apr 6, 2022, 9:44:20 AM |
Re: New Bedroom I reworked the lights on the advice of SJB007 and the shines I only have the shadows to improve. ![]() ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by sjb007 at Apr 6, 2022, 2:18:00 PM |
Re: New BedroomWow! That looks a lot more realistic. It has darkened the room down quite a bit though. It could use a bit more indirect lighting (bounce light) to give it a bit lighter feel. Or is the overhead light fixture supposed to be on? If so, that would typically be a stronger light than the others. A small hint on the bedside lights which is personal preference. They usually have two bulbs in them, one each side. This makes the fan of light broader, i.e. \ | | /instead of \|/Last thing. Is the middle section of curtain/net meant to be a plastic sheet? The upper folds have a shine which makes me think of a plastic shower curtain. If it is supposed to be a fabric net, you should remove the shininess. |
| Posted by SARRAVAL at Apr 6, 2022, 3:10:07 PM |
Re: New Bedroom ok i fix it all ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by SARRAVAL at Apr 6, 2022, 4:25:31 PM |
Re: New Bedroom And here is the job! ![]() ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by sjb007 at Apr 6, 2022, 5:28:53 PM |
Re: New BedroomExcellent job. Although if I walked in a bedroom to find that indivdual waiting for me... I would do a 180 and start running. That is one creepy looking figure. Unless "Stepford Wives" is your thing... |
| Posted by SARRAVAL at Apr 7, 2022, 9:32:51 AM |
Re: New Bedroom Hope you like this person ![]() ---------------------------------------- Un dessin vaut mieux que mille explications. |
| Posted by sjb007 at Apr 7, 2022, 1:22:55 PM |
Re: New Bedroom Much better. If I squint it could even be Lucy Liu. ![]() |
Current timezone is GMT Oct 1, 2026, 5:28:49 AM |
