Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: sweet hoe 3d will exit now because a fatal error .... |
| Print at Sep 26, 2026, 5:45:22 PM | |
| Posted by kfir at Apr 1, 2022, 5:37:13 PM |
sweet hoe 3d will exit now because a fatal error .... hi i update to the last version and try to open previous files and getting this message : "sweet home 3d will exit now ecause a fatal error in the 3d rendering system of your computer. please update the DirectX/OpengL drivers of your computer graphics card" i didnt make any changes before i update. does anyone have an answer or solution for this problem? |
| Posted by Daniels118 at Apr 1, 2022, 5:46:56 PM |
Re: sweet hoe 3d will exit now because a fatal error .... Which operating system are you running? |
| Posted by kfir at Apr 1, 2022, 5:48:58 PM |
Re: sweet hoe 3d will exit now because a fatal error .... windows 7. the version before the last was ok so i downgrade to it and still have the same problem |
| Posted by Daniels118 at Apr 1, 2022, 10:28:47 PM |
Re: sweet hoe 3d will exit now because a fatal error .... Does the error happen only when opening a file or even starting the program alone? |
| Posted by Puybaret at Apr 2, 2022, 10:58:01 AM |
Re: sweet hoe 3d will exit now because a fatal error .... Did you try the suggestions in the FAQ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kfir at Apr 3, 2022, 6:21:02 AM |
Re: sweet hoe 3d will exit now because a fatal error .... one more thing: on the new version,when i build somthing and save the file and try to open it after few minute ther no problam and everything is ok. only when i try to open an old file it open and showing me the message. |
| Posted by kfir at Apr 4, 2022, 4:32:00 AM |
Re: sweet hoe 3d will exit now because a fatal error .... Thank you Emmanuel Puybaret it works i uninstalled and install again (32bit) and it works. again, thank you |
Current timezone is GMT Sep 26, 2026, 5:45:22 PM |
