Print at Oct 2, 2026, 5:17:04 PM
Posted by KelvinUceta at Apr 6, 2022, 5:39:58 AM
Importing Blender model with textures into SH3D
I hoop this is not a doble topic, didn't found search thought the forum!
Blender OBJ model's textures don't get imported within SH3D, from my understanding textures' path should be "relative" on the .mtl file but it doesn't work:
newmtl TextureA
Ns 5.556124
Ka 1.000000 1.000000 1.000000
Kd 0.800000 0.800000 0.800000
Ks 0.178571 0.178571 0.178571
Ke 0.000000 0.000000 0.000000
Ni 1.450000
d 1.000000
illum 2
newmtl TextureB
Ns 225.000000
Kd 0.000000 0.000000 0.000000
Ks 0.000000 0.000000 0.000000
Ni 1.450000
d 1.000000
illum 1
Here my Blender's texture settings
Any help is welcome!
Kelvin
Dubito, ergo sum
Mobo: ASUS TUF GAMING Z690-PLUS
CPU: Core i9-12900K
RAM: 32 GB DDR4 3200 Ghz
GPU: MSI GeForce GTX 1660 SUPER 6G
OS: Win 11 Pro
3D: SH3D 6.6.1 and Blender
Posted by Puybaret at Apr 6, 2022, 11:18:35 AM
Re: Importing Blender model with textures into SH3D
Sweet Home 3D doesn't support map_Bump, map_Ke and map_d parameters in MTL format. It supports only textures defined with map_Kd parameter and as you noticed, you should try to save them in the same folder as the MTL file to avoid possible issues.
Posted by KelvinUceta at Apr 6, 2022, 11:32:40 AM
Merci beaucoup Emmanuel.
Kelvin
Dubito, ergo sum
CPU: Core i9-12900K
OS: Win 11 Pro
