Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Hang on furniture import |
| Print at Aug 26, 2026, 5:44:44 PM | |
| Posted by dangitall at May 3, 2022, 8:34:51 PM |
Hang on furniture import Hi all, New user here and I'm having trouble importing new furniture models on my mac. I am running v6.6a. If someone can point me to older/other versions I will try those as well. The symptom is that when I import a new furniture model as soon as I click "Continue" after choosing the model file the app hangs and needs to be forcibly quit. I have tried this with two models, one zip file I downloaded from the 3d models page and the other is a dead simple model I created with Art of Illusion. Same results with each. I've tried running in the following ways on both an M1 Macbook Pro (Monterey) and and Intel Mac Mini (Monterey): - Homebrew install - DMG install - Java jar - Java jar with Rosetta (on the M1) Can anyone give me some hint on what to try next or what information I can collect to debug this? Thanks, Dan |
| Posted by Puybaret at May 3, 2022, 10:38:47 PM |
Re: Hang on furniture import Try this version based on an older version of JOGL. As it can’t be notarized, you’ll have to run it with a ctrl + click at the first launch. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by dangitall at May 5, 2022, 7:46:30 PM |
Re: Hang on furniture import Thank you, that version works! |
Current timezone is GMT Aug 26, 2026, 5:44:44 PM |
