Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Change the wall thickness in the online version |
| Print at Oct 3, 2026, 5:51:55 PM | |
| Posted by artemisclark at Jun 2, 2022, 2:47:20 AM |
Change the wall thickness in the online version I am using the online version. All walls are automatically 3" wide, which is not realistic (wall studs 2x4 = 3.75" + drywall on each side, add 1" = 4.75". Outside walls are 2x6 etc.) Is there a way to change the wall thickness in the online version? Thank you!!!! |
| Posted by Puybaret at Jun 2, 2022, 10:39:09 PM |
Re: Change the wall thickness in the online version You can double click on a wall to change its thickness or select more walls and choose Modify walls in the contextual menu. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 3, 2026, 5:51:55 PM |
