Print at Oct 4, 2026, 8:08:32 AM
Posted by luca01 at Jun 12, 2022, 6:23:37 PM
Editing furniture from the list
Hello,
Apologies if this was asked before. I checked all the questions posted since April 2021.
Is there a way of editing the furniture dimensions by just adjusting the values from the home furniture list panel?
When I try to do that the editing window for that single furniture opens. I don't want that. I'd rather enter values in the necessary fields like in a spreadsheet for the sake of bulk and fast editing.
Thanks
Posted by hansmex at Jun 12, 2022, 8:57:16 PM
Re: Editing furniture from the list
No, this can only be done using the Modify Furniture dialogue panel.
Posted by luca01 at Jun 13, 2022, 9:56:58 AM
Oh... Maybe I should write a feature request for this. I can't be the only one feeling a need for this, can I? Oh well...
Thank you for answering though.
Posted by Daniels118 at Jun 13, 2022, 4:23:25 PM
If you need to change the size of several furniture at once, just select them all and open the edit dialog.
If instead you need a fast selective way, you can edit the home.xml file directly with a text editor.
Finally, if you have programming skills, you can write your own plugin to achieve what you need.
Posted by luca01 at Jun 17, 2022, 6:01:31 PM
Oh wow! How do I manage to keep missing the replies? Thought I had notifications on.
Thank you for the reply. Unfortunately I don't have such programming skills but editing the home.xml file sounds like something I can do. I'll try that now.
Thank you!
