Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Add "o" to OBJWriter output |
| Print at Oct 2, 2026, 6:13:54 PM |
| Posted by sjb007 at Jun 17, 2022, 10:38:16 AM |
Add "o" to OBJWriter output https://sourceforge.net/p/sweethome3d/feature-requests/1084/ Could we please have a minor (I hope) change to the OBJWriter so we can have much cleaner imports into blender, and maybe other applications. Simply needs a line at the start of each SH3D object in the export file: o <name> And that gives a single object in blender per object in SH3D, instead of the current situation where even a simple section of wall results in 6 seperate objects in blender. |
| Posted by sjb007 at Jun 17, 2022, 1:06:59 PM |
Re: Add "o" to OBJWriter output Oh, and I just checked the FreeCAD obj import, and that also can import "o" as individual objects. |
| Posted by Daniels118 at Jun 17, 2022, 2:07:04 PM |
Re: Add "o" to OBJWriter output the current situation where even a simple section of wall results in 6 seperate objects in blender. For real? Which version of SH3D are you using? I'm using 6.6a and I get no "o" lines in the exported object, so the whole home is seen as a single object when importing into blender. Am I missing something? |
| Posted by Keet at Jun 17, 2022, 8:35:54 PM |
Re: Add "o" to OBJWriter output If I'm not mistaking every "g" in the OBJ file is a separate object when importing into Blender. At least that is what I get when importing an object into Blender. SH3D OBJ exports have the g groupings. According to the OBJ specifications: Grouping: g Group name s Smoothing group mg Merging group o Object name ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by Keet at Jun 17, 2022, 9:00:03 PM |
Re: Add "o" to OBJWriter output I did a little test by exporting a single wall. The OBJ file has 6 g groups, as it should, because you want to be able to apply a texture to each "side". A single piece of wall is just like a box. Adding an o object name changes nothing when importing into Blender, the same 6 object parts remain the same. The only way to get a single object into Blender would be to merge all g groupings into a single g group. I haven't tested this but I suspect that you loose the separate textures. From my point of view a single object in Blender is virtually useless, you want things to be as separated as possible because it allows you to manipulate them individually. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by sjb007 at Jun 17, 2022, 10:50:00 PM |
Re: Add "o" to OBJWriter output Allow me to elaborate. Blender (I'm on 3.1) has options when importing obj files. (Gear cog, top right). There is an expander panel named "Geometry". These affect how the data is interpreted. You can select between Split, and Keep Vert Order. The "Keep Vert Order" option will create a single object. If "Poly Groups" is on it will create vertex groups in the object based on the "v" labels that allow you to select parts of the mesh. This has some specific useful use case I read somewhere, but not very interesting for us SH3D users. Under "Split" is the bit I/we are interested in. If you only select "Split by Object", it will create a single blender mesh object per "o" label in the obj file. The "Split by Group is maybe the default (I lost track as I've edited my blender importer python code.) On it's own you get blender objects based on "v" labels. If you combine it with "Split by Object" you will still get an object per "v" but the naming convention is "<o-label>_<v-label>". All the above is observable with the example "with o" test file in the linked ticket. Simply adding the "o <o-label>" will make SH3D and Blender work really nice together. I'm currently trying to modify the blender import to add the option to have the best of both worlds: "Split by Object" + new "Group to Vertex Groups" (yeah the name isn't great). The idea is that each "o" in the obj file create a seperate blender object, and each of the sub "v" groups create a blender vertex group under that object. This allows you to easily select or operate on the seperate parts of the mesh. Think of a bed, with the pillows and duvets as seperately selectable vertex groups. I'm kind of stuck at the moment because the vertex group code uses an array of vertices and indexes to reference them. Unfortunately when you "Split by Object" it appears the vertices indices change, so the vertex groups don't work. I hope that cleared up any misunderstanding. |
| Posted by sjb007 at Jun 17, 2022, 10:53:46 PM |
Re: Add "o" to OBJWriter output the current situation where even a simple section of wall results in 6 seperate objects in blender. For real? Which version of SH3D are you using? I'm using 6.6a and I get no "o" lines in the exported object, so the whole home is seen as a single object when importing into blender. Am I missing something? In case it wasn't clear I exported an obj file, and manually added the "o" to test the theory, and it works. Theree's an attachment in the linked ticket that has the "with o" test file I've been experimenting with. If you get a single object, you need to examine the options as I mention in my previous comment. You likely have "Keep Vert Order" selected. |
| Posted by sjb007 at Jun 17, 2022, 11:25:00 PM |
Re: Add "o" to OBJWriter output A couple of other quick thoughts on possible additions to the blender obj importer to improve SH3D -> Blender:
| Posted by Daniels118 at Jun 18, 2022, 6:12:45 AM |
Re: Add "o" to OBJWriter output @sjb007 (Gear cog, top right). There is an expander panel named "Geometry" You're right! I did expand the gear button, but I didn't see the "geometry" accordion... my poor eyes! Thank you! I agree with you about having the "o" lines, splitting by geometry produces too many entries (even door handles gets separated), many of which have poor names. P.S. after importing, all the imported objects are selected by default. Just type "s.01" and press enter to scale down 100 times (centimeters -> meters). |
| Posted by sjb007 at Jun 18, 2022, 1:29:54 PM |
Re: Add "o" to OBJWriter output P.S. after importing, all the imported objects are selected by default. Just type "s.01" and press enter to scale down 100 times (centimeters -> meters). Oh, I know how to scale. That's five key presses! "Ain't nobody got time for that!"... more seriously, when you are doing the import 50 times trying to figure out how in the hell the importer works, it does get tedious. |
Current timezone is GMT Oct 2, 2026, 6:13:54 PM |
