Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Display in Separate Window as own instance, or... |
| Print at Oct 3, 2026, 8:58:49 PM | |
| Posted by Soulbrother at Jul 17, 2022, 7:58:28 AM |
Display in Separate Window as own instance, or... The Display in Separate Window (crl+alt+Y) opens a new window, but I cannot switch between main window and this window. Is that normal? I use WIN10, latest updates and SH3D V7.0 (for V6 it is the same) Using on 2 monitor workstation is fine, but it is not an advantage at PC with only 1 monitor. So pefect would be to have this window as own instance, to be able to switch with the usual windows shortcuts (ALT+TAB) OR to integrate some shortcuts in SW3D, to be able to change the size of the areas. Instead of pushing with the mouse, jus a fast shortcut, would help me much. As I guess, this can be done only if some presaved workspace layouts can be used, this wuold be my wish of today ;-) |
| Posted by Daniels118 at Jul 17, 2022, 1:05:09 PM |
Re: Display in Separate Window as own instance, or... You can try the Pan 3D View plugin, it adds a shortcut (ctrl+space) to maximize in turn the 2D and 3D views. |
| Posted by Soulbrother at Jul 17, 2022, 3:32:47 PM |
Re: Display in Separate Window as own instance, or... Thanks, that sound promising, I´ll try!! |
Current timezone is GMT Oct 3, 2026, 8:58:49 PM |
