Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Change The Categories in the Menu |
| Print at Oct 7, 2026, 3:29:33 AM | |
| Posted by kaotiktrendz at Aug 8, 2022, 9:15:27 PM |
Change The Categories in the Menu So I would like to rename or change the "Category" names that in the descriptions when modifying furniture or when using the furniture editor. Is there a way I can delete a couple of the existing categories and rename a few others? Thanks. |
| Posted by Puybaret at Aug 8, 2022, 11:18:14 PM |
Re: Change The Categories in the Menu You can change categories only for individually imported furniture or with the Furniture Library Editor for furniture libraries. The FAQ How can I create a new category of furniture? will have you give a hint. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kaotiktrendz at Aug 8, 2022, 11:57:25 PM |
Re: Change The Categories in the Menu So just for clarification I cannot delete a category completely from the drop down menu? I know how to import furniture and make a category for that library, but the issue is when I open a different library, that category is gone and the default categories are the only things showing. |
| Posted by Puybaret at Aug 9, 2022, 6:51:00 AM |
Re: Change The Categories in the Menu In the Furniture Library Editor, there are 12 default categories at the moment and you can’t delete them. But Sweet Home 3D behaves differently: only categories containing at least one item will appear in the Category drop down list. So if you created a new category while importing a piece of furniture, but then delete the imported piece, the new category won’t appear anymore. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kaotiktrendz at Aug 9, 2022, 8:43:31 AM |
Re: Change The Categories in the Menu Yea I understand that the category will show in the menu if a piece of furniture is in the library under that category name. Would be nice to eventually delete the base categories that I do not use. Ive deleted the original furniture and then added the furniture I want, but I still have categories in the menu that aren't associated with any of the furniture. |
| Posted by Puybaret at Aug 9, 2022, 9:01:31 AM |
Re: Change The Categories in the Menu Sorry, I don't think I'll add the option to remove the 12 default categories from the Furniture Library Editor. It's just a side tool and not that important. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 7, 2026, 3:29:33 AM |
