Print at Oct 7, 2026, 12:24:22 AM
Posted by dkaparis at Aug 16, 2022, 3:32:15 PM
Error exporting SVG
Greetings,
Using Sweet Home 3D 7.0.2 under Archlinux and OpenJDK Runtime Environment (build 11.0.16+8). When I select the Plan->Export to SVG Format command and specify file, I get the following dump on terminal:
java.lang.NoClassDefFoundError: org/freehep/graphicsio/svg/SVGGraphics2D
at com.eteks.sweethome3d.swing.PlanComponent.exportToSVG(Unknown Source)
at com.eteks.sweethome3d.swing.PlanComponent.exportData(Unknown Source)
at com.eteks.sweethome3d.swing.MultipleLevelsPlanPanel.exportData(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.exportToSVG(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController$38.call(Unknown Source)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.lang.ClassNotFoundException: org.freehep.graphicsio.svg.SVGGraphics2D
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
... 13 more
The produced file is zero size.
Could this be a packaging issue? Any ideas how to diagnose further?
Thanks,
Dimitri
Posted by Puybaret at Aug 16, 2022, 6:34:09 PM
Re: Error exporting SVG
This looks like a packaging issue. Use the official release available at Download page.
Posted by dorin at Aug 17, 2022, 8:20:26 AM
I use official version (from download page) under linux (debian).
Running SweetHome3D & SweetHome3D-Java3D-1_5_2 it's OK (produce the expected svg result).
I receive the same error (in terminal & 0 size file) ONLY when I use nimbus.
(-Dswing.defaultlaf=javax.swing.plaf.nimbus.NimbusLookAndFeel)
Maybe is not the only one issue under this settings.
With SweetHome3D-6.6 all work OK.
Posted by dkaparis at Aug 17, 2022, 9:43:09 PM
When running the downloaded jnlp version on the same system with javaws, the SVG export works without error.
I filed a bug report at https://bugs.archlinux.org/task/75632.
