Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: how to draw curved upwards wall? |
| Print at Oct 8, 2026, 6:04:59 PM | |
| Posted by LouDminsk at Aug 17, 2022, 9:49:13 PM |
how to draw curved upwards wall?Hello, community! Can you tell me how to draw a semi-circular wall? I mean semicircular from above, that is, the top edge is curved upwards, not parallel to the bottom. How to draw just a curved or round wall, I have seen many youtube videos. But I have not found a solution to my problem. P.S. By the way, the second question would be how to make a semi-circular roof on this wall! |
| Posted by Daniels118 at Aug 18, 2022, 10:13:21 AM |
Re: how to draw curved upwards wall? Do you mean something like this? |
| Posted by Puybaret at Aug 18, 2022, 11:11:38 AM |
Re: how to draw curved upwards wall? Or maybe like the roof in this thread? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Aug 18, 2022, 11:55:38 AM |
Re: how to draw curved upwards wall? Workaround: - draw a straight wall (doesn't work with curved wall) - import a cylinder and mark it as Door/Window - insert the cylinder in the wall at the correct elevation and size - make the cylinder invisible (cutout will remain) image [img]https://www.mediafire.com/view/b74wryub5...urved_wall.PNG/file[/img] Notes - SH3D can make a curved/round/oval cut-out in a straight wall; in a curved wall the curved part will be circumscribed by a rectangular box - most/many cylinders/circles are described as a set of straight lines; for a good result you need a cylinder that is composed of many small parts (or even a real circle); (see image for curve with angles) H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Daniels118 at Aug 18, 2022, 12:20:13 PM |
Re: how to draw curved upwards wall? Hi Hans & Emmanuel, I've found that when 2 windows bounding boxes overlap, only one window is taken into account to cut the wall within the intersection region. Is there any simple workaround for this? Or, are there plans to merge the cutout shapes when they overlaps? Here the green shape is used to cut the wall with the roof shape, and the buggy window is in red: ![]() The dimension lines are there just to line out the bounding box of the green shape. |
Current timezone is GMT Oct 8, 2026, 6:04:59 PM |
