Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Furniture Library Editor |
| Print at Oct 5, 2026, 6:26:59 PM | |
| Posted by GrahamI at Aug 23, 2022, 2:17:32 PM |
Furniture Library Editor How does one Install this feature on an MS Windows PC? I just see a whole bunch of Java files and I know nothing of Java. Regards Graham ![]() |
| Posted by Puybaret at Aug 23, 2022, 3:32:29 PM |
Re: Furniture Library Editor Java files??? The Furniture library editor is a JAR executable file. Install a JRE or a JDK then double-click on the JAR executable file to run it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by GrahamI at Aug 24, 2022, 8:56:54 AM |
Re: Furniture Library Editor Thank you. All is resolved now. I now have to learn how to use it. I want to create a Post and Rail Fence, often used in a rural environment here in Australia. Regards Graham |
| Posted by Keet at Aug 24, 2022, 10:23:00 AM |
Re: Furniture Library Editor I want to create a Post and Rail Fence, often used in a rural environment here in Australia. You don't need the Furniture Library Editor to create new furniture. For your fence you could create a nice fence by combining multiple resized Box objects. Variations can be made by using stretched cylinder objects.You should get the geo models from https://sourceforge.net/p/sweethome3d/d-models/299/ which are very useful for creating furniture details. For example to create different post tops. Or put a Sphere halfway in the end of a cylinder to get a nice rounded top. Once you have all your parts combined you can export them to a single object which can be imported in the Furniture Library or just used as you created it. The Furniture Library is mainly to group multiple furniture objects into a single Library for easy import or to create a collection of your custom made furniture. It's also important for adding and changing a few properties for objects that are specific for Sweethome3D and can't be added to a stand-alone object. You can, for example, change the cut-out made by windows, doors, and staircases. The Furniture Library allows to add these features. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
| Posted by GrahamI at Sep 7, 2022, 6:30:13 PM |
Re: Furniture Library Editor Is there "How to Use" Guide for this? |
| Posted by GrahamI at Sep 8, 2022, 6:40:50 AM |
Re: Furniture Library Editor Thank you Keet. That is very helpful and much appreciated advice. I'm learning heaps here. My thanks to all for your help. Regards Graham |
| Posted by GrahamI at Sep 9, 2022, 5:08:37 PM |
Re: Furniture Library Editor What a GEM of advice that the was! Now, I haven't created my Post and Rail Fence yet. But, I've learned so much more. One Step at a time Sweet Jesus is my attitude! Regards Graham |
| Posted by Puybaret at Sep 9, 2022, 5:14:03 PM |
Re: Furniture Library Editor Is there "How to Use" Guide for this? You can find some explanations here.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 5, 2026, 6:26:59 PM |
